Use the following procedure to display the SPB-PIM Gateway brouter port information. This procedure displays the administrative (configured) state of the interface as well as the operational state, and the HELLO and JOIN PRUNE intervals. An interface can be administratively ENABLED but operationally DISABLED if, for example, mvpn is not enabled on the VRF, or spbm <spbm-instance> multicast enable is not configured.
Switch:1#show ip spb-pim-gw interface gigabitethernet 1/2
                                  Port Ip Spb-pim-gw
ORT-NUM  OPSTATE    ADMINSTATE  HELLOINT  JPINT
1/2      Disabled   Enabled     30         60
Variable definitions
The following table defines parameters for the show ip spb-pim-gw interface gigabit command.
| Variable | Value |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} | Identifies the
                                    slot and port in one of the following formats:
| vrf WORD<1-16> | Displays SPB-PIM Gateway interface information for a specific VRF. |
| vrfids WORD<0-512> | Displays SPB-PIM Gateway interface information for a range of VRF IDs. Note:
                                     Enter a single VRF ID or multiple VRF IDs separated by ‘,‘ or enter a range of VRF IDs ‘x-y‘. |
